TwinTurbo.NET: Nissan 300ZX forum - Try pushing the fork back by hand, If it moves
Subject Try pushing the fork back by hand, If it moves
Posted by Spddracer on April 08, 2010 at 8:14 PM
  This message has been viewed 73 times.
In Reply To clutch pressure posted by TJSB on April 06, 2010 at 06:50 PM
Message more than where the slave is at rest at the fork or pivot ball is broken.
If that is ok you probably just need to loosen up the adjustment at the pedal clevis a little so the piston inside the master can get some fluid in it. If the pedal adjustment is to tight you will never get it bled as no fluid can get in the piston area of the master.
Zspeedperformance.com
